Re: Trying to locate Farmall H main bearing kit .002 und...
Posted by gene bender on February 16, 2012 at 13:15:03 from (67.55.226.168):
In Reply to: Trying to locate Farmall H main bearing kit .002 undersized posted by Yooper Farmall on February 16, 2012 at 07:30:18:
You guys make me laugh "undersize" if the crank is worn you need "oversize" as they are thicker to make up what the crank is worn. I spent too much time making new brass bushings for worn outstuff when the shafts had wear and then after turning them true needed oversize to get a good fit. The crank is under size after wear so you need oversize bearings to fit.
