Re: Trying to locate Farmall H main bearing kit .002 und...
Posted by Owen Aaland on February 18, 2012 at 13:43:35 from (216.47.34.216):
In Reply to: Trying to locate Farmall H main bearing kit .002 undersized posted by Bob M on February 16, 2012 at 07:30:18:
To get the same as a .002 undersize bearing you would need to use .001 shim stock and put it behind both bearing inserts. You should also sand a little off the end of the insert to keep the bearing crush the same.
Many years ago you could get tapered shim stock. It was .001 on the sides and .002 in the middle. When using that you put it behind only one insert, usually the upper on the rods and lower on the mains since they would be ones with the most wear. The last time I tried to find some I didn't even find anyone who even heard of it.
