Re: Farmall Super C - Question
Posted by C. Amick on February 18, 2012 at 17:27:54 from (71.53.199.210):
In Reply to: Re: Farmall Super C - Question posted by gene bender on February 18, 2012 at 17:14:57:
The crossmember hits across the front of the tires. The spacing of the tires isn't the problem. The tractor I took the blade off of must have had smaller wheels? I'll probably just have the blade frame cut, extended, and re-welded. It will be cheaper than changing the tires out.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
