Re: Farmall tractor gas line problem
Posted by Donald0827 on February 20, 2012 at 16:31:57 from (50.132.97.66):
In Reply to: Farmall tractor gas line problem posted by Jim Isler on February 20, 2012 at 14:26:39:
He bypassed the carb with the starter turning - opened the plug and put gas directly into the intake manifold, but couldn't get the pistons wet.
Vacuum leak is a possibility, but hard to tell and where would this be? It seems to be getting enough suction.
Also, he's 1500 miles away, no internet, so we're chatting about all of this via phone... I am not seeing what he is : )
