Re: Farmall tractor gas line problem
Posted by gene bender on February 20, 2012 at 17:30:27 from (67.55.226.168):
In Reply to: Re: Farmall tractor gas line problem posted by Donald0827 on February 20, 2012 at 16:31:57:
You are all messed up there isnt any plug to remove and pour gas into the intake. Better get someone who knows what to do as you have something mixed up in your method of starting tractor
