Thanks for the reply. I've only got one set of rear remotes and those and the clutch side remotes are controlled by the inside tractor lever. The brake side remotes are controlled by the outside lever. I don't think I had that lever in the float position but to be honest I didn't think about that, I may have - I'll try that again. I'm fairly certain it's plumbed correctly, the inlet and outlet on the valve are plumbed to the side remote and the arm cylinders hooked to one spool and the tilt cylinders to the other.
The loader was actually off of a bi-directional versatile, we stretched the frame on it slightly and fabbed mounts to make it fit. There was no valve included, I'm using a Cross brand 2 spool valve. It does have a power beyond port which I'm not using currently. I thought that was only to add a 3rd spool?
Is there a pressure relief in the tractor that I could be tripping? I'm not sure on the specs of the external valve, maybe there is something in there that I need to change?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
