starting farmall cub
Posted by Bob on September 12, 2000 at 14:59:20 from (208.159.102.66):
Been trying for a week now to get farmall started, replaced carb. in early spring with a new replacement carb. Just put on another manifold, has newer plugs, new coil last year, compression and timing check out ok, have a good gas flow to the carb, cleaned plugs, checked spark plug wires. It cranks and cranks, doesn't seem to be getting gas to the cylinders. Have heard that the new replacement carbs are no good???? It was running fine earlier in summer, then started running rough occasionally , last time i had it started, ran ok until i engaged mower, then ran real rough, couldn;t keep her running. Been down hill since then. Any ideas ????? thanks.
Post A Followup
: Re: starting farmall cub
