Re: 656 resistor
Posted by Janicholson on February 21, 2012 at 16:46:29 from (67.72.98.45):
In Reply to: 656 resistor posted by Jamie656 on February 21, 2012 at 14:38:30:
The resistor does go between the ignition switch I terminal, and the coil+ terminal. An additional wire goes from the coil + to the starter solenoid I terminal. This added wire bypasses the resistor when starting to increase the voltage. The solenoid only supplies voltage to it when the engine is cranking, so it is not used during running of the tractor. Please find useful diagrams attached. Jim
