Re: Where to run battery cables on a late syle H
Posted by rustyfarmall on February 22, 2012 at 06:09:11 from (216.248.71.224):
In Reply to: Where to run battery cables on a late syle H posted by sflem849 on February 22, 2012 at 05:30:24:
Battery negative goes directly to one of the posts on the starter button. The other switch post goes directly to the starter post. Battery positive is grounded to the inside starter mounting bolt.
#1 gauge is more than adequate, and heavy duty, cast copper terminals are better than those stamped steel ends used on most cables.
