Where to run battery cables on a late syle H
Posted by Yooper Farmall on February 22, 2012 at 05:30:24 from (141.210.112.16):
I've got an early H that had the foot peg starter, when my steering post broke I replaced it with one from a later H with the bracket for the starter button mounted on the opposite side of the post from the light switch box. I'll need to get longer battery cables which kinda sucks because the previous owner had just put on new thick guage cables.
My question is where do the longer cables run, do they run through the hole in the rear gas tank mount where the starter button used to reside, or do they just run along the left side of the rear gas tank mount? I haven't been able to tell from the Farmall pictures I've been collecting.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
