Re: H Crank Handle, and A Charging Problem
Posted by John T on February 23, 2012 at 08:04:35 from (66.87.7.250):
In Reply to: H Crank Handle, and A Charging Problem posted by George Rausch on February 23, 2012 at 07:44:12:
On that 10SI one of those small terminals (voltage sense) is jumpered direct up to the big main output stud so the internal voltage regulation circuit knows what charge rate to maintain. The other small terminal is used for excitation voltage and usually wires to the ignition switches IGN terminal which becomes hot when the ignition is switched ON (or to input side of ignition coil) via an in line series diode or resistor to prevent the ignition coil from backfeed.
Is yours wired that way?? If not I wouldnt expect it to work properly
John T
