From what I can tell, they raised the fill neck a little bit on the later models. That makes sense b/c you need a longer neck funnel to fill this one and it's a pain to reach in and get the stick out.
I'd appreciate you measuring that - thanks! How well does it seal w/ just the orings? There's quite a bit of dirt that collects in the space under the platform before the filler neck.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
