Gear shift pattern on a Regular
Posted by Mark Poss on February 25, 2012 at 06:38:47 from (173.23.242.23):
Can someone tell me the gear shift pattern on a Regular so I can put it in high gear to pull start it. Thankyou, Mark.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
