Posted by D Slater on February 25, 2012 at 14:32:36 from (184.15.49.116):
In Reply to: 1953 Super M posted by L. C. on February 25, 2012 at 11:06:07:
First off the battery box under the seat is not original for a SM with that serial #. Most times a date code on the transmission is found on the side in front of the brake pedals. Clutch housing on top and can be hard to see for a belt pulley gear box. Axle housings on the back or front. Transmission top near where the right foot would sit. Maybe just ahead of the battery box. That serial SM housings will probably have some X date codes. Maybe most of them. To ID the engine look for the casting # and letters following the number, above the oil filter on the side of engine block. See if the engine has a serial # stamped in a raised flat area below # 1 spark plug and just above the tin cover on the side of the engine. If it came from another M tractor the letters in front of the serial # will confirm that.
Serial prefix for a M engine is FBKM. Cast # for a 45 block that came in a M tractor would be 6722 followed by letters that I think would be DH.
This post was edited by D Slater at 15:04:54 02/25/12.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
