I would much rather see you adjust the bearings to fit the actual crankshaft journal. Here is what I have done in the past on F20/Regular engines. With the piston/rod assemblies out of the engine, I take one by one and fit them to the crankshaft until I have found that with X number of shims on each side the crankshaft will not turn but with X+1 shims on each side of the rod the crankshaft will turn freely. Follow this procedure with each rod bearing in turn, once this is done, THEN install the pistons/rods into the engine and bolt them to the crankshaft. I have followed this procedure on two Regular engines that I have rebuilt and have found it to work the best.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
