Posted by SDE on February 25, 2012 at 21:12:46 from (174.124.49.15):
I made a shaft that is .003 larger than the crankshaft journals. I put the connecting rod in a vise and then removed shims until the shaft was tight in the bearing. I then turned the shaft with a pipe wrench. After removing the shaft, I would scrape the bearing. I did this until the shaft showed that it was making contact on at least half the bearing surface. Some had two more shims on one side than the other. I put them back so that each side had the same amount. This is my first time working with babbit bearings. Am I doing it OK so far? I saw in the archives that you install them onto the crank so that they are tight and then add a shim to each side until they are loose. Will the way I did it work OK?. Thank you Steve
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
