Re: adjusting the F-20 rod bearing
Posted by gtski on February 26, 2012 at 01:56:22 from (4.131.17.84):
In Reply to: adjusting the F-20 rod bearing posted by SDE on February 25, 2012 at 21:12:46:
SDE, your way might work if every journal on the crank was exactly the same, but the method Nebraska Kirk describes is preferred for variances in rods and cranks.
