Re: SMD Hydraulic system design
Posted by State of Jefferson on February 26, 2012 at 14:07:32 from (75.210.97.142):
In Reply to: SMD Hydraulic system design posted by Dan MD on February 26, 2012 at 12:07:29:
I re-plumbed my SMTA a couple years ago. I ran 3/4 lines from the pump through the valves then through a spin-on filter housing, and back to the res. I used the 3/4" only for the purpose of creating less friction, and hoping to dissipate more heat. Weather or not it helps any significant amount, I cannot say.
One concern I would have about using the gutted belly pump as the only res, is weather the pump will be able to suction-feed itself. My understanding is the live pumps need gravity feed, but I may be wrong on that point...
Another thing you will need to consider, is pressure relief, the valve you have is likely designed for a modern system, commonly in the 2000psi range, your live pump only puts out about half of that, and if you don't have low enough pressure relief, something is gonna give. It will either be the cam timing gear, or your pump. Don't ask me how I learned this little nugget of info... But it is not a lesson you wanna learn the hard way. You can get add-on pressure relief valves from Northern, or Surplus center, among others.
Good luck
Ben
