Re: SMD Hydraulic system design
Posted by Dan MD on February 26, 2012 at 17:06:33 from (72.160.225.142):
In Reply to: Re: SMD Hydraulic system design posted by State of Jefferson on February 26, 2012 at 14:07:32:
My tractor came with the belley pump reservoir feeding the pump. I was told lots of people did it this way without problems.
I special ordered a valve with a 500-1500psi relief.
