Re: Farmall super C engine in Farmall C??
Posted by Lmack on February 27, 2012 at 19:58:06 from (24.131.58.167):
In Reply to: Farmall super C engine in Farmall C?? posted by danto on February 26, 2012 at 20:40:21:
I think (you do need to get more information) that the water pump problem will give you some grief. If you try to install the SC engine with the water pump in place there is space problems with the C. If you delete the water pump there may be bolt up problems. You will end up bringing over the entire front bolster from the SC and the radiator for the SC is taller. The tin will not fit. The C engine is easy to rebuild. You need sleeves and possibly pistons. If the crank is in good condition no machine shop work is needed on the bottom of the engine. You would need a typical valve job on the top which might be a machine shop job. It is possible to oversize the pistons using larger sleeves and achieve the same displacement as the SC. Why swap out the engine?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
