Re: Farmall super C engine in Farmall C??
Posted by gene bender on February 28, 2012 at 04:44:37 from (67.55.226.114):
In Reply to: Re: Farmall super C engine in Farmall C?? posted by Lmack on February 27, 2012 at 19:58:06:
You are all messed up with your info the blocks are the same. The water pump will bolt on any A,B,orC and can be used without changing radiators it has been done many many times. The only difference in bolsters is where the steering in-put shaft is. You can put a Bs steering if you would like and by the same the Cs could be used on a B if you wanted. Ive seen a B with seat moved to the center above the tranny and a Cs steering sector used.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
