Re: More 350 TA Questions
Posted by mkirsch on February 28, 2012 at 05:47:46 from (64.80.110.74):
In Reply to: More 350 TA Questions posted by 1sarge on February 26, 2012 at 15:36:56:
Ideally, you should use CaseIH HyTran, or at least something marked as compatible.
IIRC, the book specifies SAE30 non-detergent motor oil with an additive, but this concoction was replaced by HyTran in the early 1960s.
You do NOT want to use "Gear Lube" it is too thick and sticky, and the TA will not work properly.
