Posted by Bill_SC on February 28, 2012 at 09:21:00 from (207.144.207.219):
Had water push back up through radiator cap the other day while using the tractor. Let it cool down and was fine until it got hot enough again. Took out thermostat and filled with water then started it to see if water was moving through the system - no movement. So a bad water pump was assumed. I removed the water pump, but I declare I can't "see" anything wrong with it. No chipped/broken fins, it wasn't leaking, bearing doesn't seem to have any play in it. Has always ran just fine and had good anti freeze in it. Is it possible that the pump is bad even though it doesn't look to be? Any suggestions?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
