Re: IH WD-9 Compression Lever
Posted by WD9ER on February 28, 2012 at 12:51:41 from (65.127.84.74):
In Reply to: IH WD-9 Compression Lever posted by WD9ER on February 28, 2012 at 10:14:02:
I do not have a copy of the service manual? Would it be possible to send a copy of those specific pages my way? I didn’t remove any of the valves behind the carb or the friction disc on the “diesel side.” All that I did was use engine degreaser and steel brush to clean up those areas. Is it possible that by just cleaning these areas could have reduced the friction enough to cause it to not changeover correctly?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
