Posted by WD9ER on February 28, 2012 at 10:14:02 from (65.127.84.74):
As I have been in the process of restoring my WD-9, I cleaned up the linkage for the compression lever (LH side of steering column). Previously, it dropped down to the diesel compression when the throttle lever was moved in the diesel range. It no longer does this until the throttle is all the way into the WOT position for the diesel. Is there an adjustment that needs to be made? If so, where is that at? My assumption is that as soon you switch from gas to diesel, it should automatically drop the compression lever to the diesel cycle, but maybe it was suppose to be done manually. Thanks!
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
