Re: 1466 hyd valve problem
Posted by LarryT on February 28, 2012 at 19:55:14 from (107.4.52.32):
In Reply to: 1466 hyd valve problem posted by Larry B 1486 on February 28, 2012 at 17:40:15:
Almost sounds like you cut an "O" ring. I had that happen once with similar results. Had a heqq of a time getting the spool out. Try the link below and see if the illustration helps.
