1466 hyd valve problem
Posted by Larry B 1486 on February 28, 2012 at 17:40:15 from (98.19.160.144):
The 1466 that I bought two years ago, has two rear remote valves but one is locked up in one direction. I can pull back on the leaver to raise the cylinder but it will not push foward to lower the cylinder. I took the linkage off and put a pair of vice grips on the end of the valves plunger and I can push it in but cannot pull it out. The other valve works fine. What could be locking it up to keep from the plunger going foward from the center position? It does have pressure when you push the valve back from the center position. Can I take the cap off the back, the one that takes a 1 1/2 socket and see whats going on? Appricate any help.
