Re: 1466 hyd valve problem
Posted by The tractor vet on February 28, 2012 at 20:50:31 from (75.19.126.251):
In Reply to: 1466 hyd valve problem posted by Larry B 1486 on February 28, 2012 at 17:40:15:
Try taking the plug (if it is still in the back cap) and try backing off the latching valve screw and see if that will not cause it to UNLATCH . If this is not the problem then you are going to have to get it apart.
