Re: Cub Shutdown
Posted by Andrew Z on February 29, 2012 at 16:46:38 from (64.148.7.32):
In Reply to: Cub Shutdown posted by BruceS. on February 29, 2012 at 16:43:14:
Sounds like you have a dead coil, should restart when cold again. When it occurs again check to see that you have a good hot blue/white spark if it is yellow/orange or none at all you found your problem.
Andrew
