Cub Shutdown
Posted by BruceS. on February 29, 2012 at 16:43:14 from (76.15.9.253):
Was plowing snow this afternoon with my cub. Was running fine for over an hour, then abruptly stopped running. No sputtering, no attempt to try to keep running, just stopped, like turning off an ignition key. Does anyone have a clue as to what happened? Does not seem to be a gas problem, tank was over half full. Acts like spark, but why?? Engine turns over fine, but will not try to fire. I'm mystified.
