Re: Cub Shutdown
Posted by wisbaker on February 29, 2012 at 17:27:16 from (207.118.174.240):
In Reply to: Cub Shutdown posted by BruceS. on February 29, 2012 at 16:43:14:
"Just like turning off the ignition key"-I think you answered your own question, I'd check the coil, ballast resistor (if it has one), ignition switch/key and condenser. When It quits try a test lite on the coil post (the one coming from your switch), that'll tell you if you're getting power to the coil, work your way forwards or backwards until you find the problem. Go to the Ford 8N board and search for "50 tips" a lot of good info that you can apply to your Cub.
