Re: Where (all) is my injection pump leaking?
Posted by Janicholson on March 02, 2012 at 16:03:29 from (67.72.98.45):
In Reply to: Where (all) is my injection pump leaking? posted by Dalrymple on March 02, 2012 at 14:10:56:
As D Slater points out, there is supposed to be
engine oil in the pump (up to the level of the
petcock - visible to the front) if it is higher than
that, and the seal is bad on the shaft, it will leak readily. Transfer pump seals can be replaced. It
is a careful take pictures type task, with real
cleanliness. By the book. Jim
