Re: Hydraulic leaver on SH
Posted by D Slater on March 05, 2012 at 05:49:58 from (184.15.8.10):
In Reply to: Hydraulic leaver on SH posted by Va Gasman on March 04, 2012 at 13:54:30:
third party image
If its like the picture do you mean the rear valve lever is frooze and won't move or it doesn't do anything when moved? As others posted the rear valve will operate a double acting hydraulic cylinder. But to use it the front lever needs moved and the little lock under the lever turned to keep it in place. Front lever will only operate cylinders single acting if hose is hooked to its outlet ports. But for it to have pressure the rear lever needs locked to the engaged position. Operators manual for the tractor would explain better.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
