Hydraulic leaver on SH
Posted by Va Gasman on March 04, 2012 at 13:54:30 from (75.192.138.243):
I have this different SH that has Live Hydraulics. There are 2 levers to Hyd. system. one works a lever on the side of the Tank housing. The other is attached to a smaller lever that looks as if it is connected to a valve. This Second lever will not operate. What should I try?
