I made a set of plates for a MD three point by using a housing gasket to place the holes directly on heavy paper. Then took the paper to the tractor and cut out material to allow the bolt holes to clear the material around the flats on the housing. The holes were perfect, I made a copy of it by transfer to 1/8" tempered masonite. I jacked up the tractor, and bolted it on. My mounts were for cat 1 and 2 t point, so were different than for FH. I also designed into the plates the rock shaft bearing supports for pillow blocks. The 1/2" thick plates were flame cut, then drilled (transfer punches with the masonite). Today I would use the gasket in a large format digitizer then draw my bracket around the gasket holes. CNC plasma torching the outline, then using the cgasket to position the holes for drilling would be choice. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
