Oil blow out of exhaust ports on fresh Farmall 706 rebuild
Posted by Deuce on March 07, 2012 at 18:14:41 from (208.103.41.37):
I have a Farmall 706 that I completely rebuilt with new sleeves, pistons, rings and rebuilt head. Once I got it fired up it seemed to run perfect but started leaking (significant amounts) oil from the exhaust ports of at least 4 cylinders within 15 minutes running.
(double made sure the rings were installed correctly when assembling the pistons!)
I removed the valve cover to see if all the valve stem seals are in place and all appear to be ok.
Any idea what might be causing all this oil to blow out the exhaust?
Thanks in advance!!
