Re: Oil blow out of exhaust ports on fresh Farmall 706 re...
Posted by Janicholson on March 07, 2012 at 18:29:17 from (67.72.98.45):
In Reply to: Oil blow out of exhaust ports on fresh Farmall 706 rebuild posted by Deuce on March 07, 2012 at 18:14:41:
More than likely not oil(assumes it is a diesel). Likely that two things are happening at once. Diesel engines when first started and not worked hard "slobber" this is a mix of carbon black and condensed water. (looks like oil but it does dry into spots or stain like runs) This is the nature of tractor diesels of that vintage. If worked hard, it will stop.
The second is leaky exhaust gaskets. If the manifold leaks the gasket and or surfaces were not perfectly flat or possibly tightened correctly. It is a working machine. Puttering around low speed or load operation and parades are slobbering conditions. If the staining is not too bad, I would live with it. If exhaust is escaping radically (use a small rubber hose as a stethescope all around the manifold) It needs to be fixed, or retorqued. Jim
