Posted by 460 training on March 10, 2012 at 19:50:26 from (173.213.142.69):
Bought 460 last summer. When I got it home, found it would start sputtering and die when worked, or throttle cracked open. Usually pulling the choke would save it. Checked fuel supply - good flow. Checked for air leaks - none found. Checked spark, intermittent - replaced coil and found resistor bad - replaced both and started running/responding good, but I really did not work it after that. Today I started using it to harrow, about 10 min in the problem seems to have returned. Now it will only run with choke on. I will go back through but am looking for other suggestions. Also this tractor has 560 engine (263 CI). Is it possible that it still has the 460 carb and not getting enough fuel? Are the carbs diff 460/560? Thanks in advance.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
