Look behind the tube fitting where your gas line connects for a screen. It may be plugged with dirt or rust. If that carburetor has a solenoid on the carburetor it may not be opening fully. If it has a main jet adjusting scr/w you need to open that to enrich the fuel mixture. If none of this helps you probably need to clean the carburetor by soaking in carb cleaner and blowing out the jets with air pressure. Check your float level to make sure it's set high enough. When you need to keep an engine choked is a sign the engine is starving for fuel. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
