Posted by T Epp on March 11, 2012 at 13:00:53 from (66.222.110.226):
In Reply to: Super A not charging posted by T Epp on March 11, 2012 at 08:21:35:
I have it hooked up now wired as a 3 wire and it seems to be charging.I have not installed a diode yet so I have to pull the coil wire at the ballast resister to shut it down.I have checked the wire to the coil after shutting it down and there isn't any voltage reading.I'm going to get the materials this week and rewire everything. I did check the wires on the amp gauge and it seems to be connected correctly.Wire coming from alt to gauge on one side and wire to starter on the other.There is a wire that originally came from the gen/reg circuit that goes to the ignition switch the P/O had connected together with a wire nut at the alt.Since all the wiring is old and brittle and the lights don't work I figure this is as good a time as any to rewire it all. I think I'll change the amp meter to maybe a 30amp, this might give a better reading.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
