Re: Super A not charging
Posted by Janicholson on March 11, 2012 at 15:45:10 from (67.72.98.45):
In Reply to: Re: Super A not charging posted by T Epp on March 11, 2012 at 13:00:53:
Probably will not change the reading. If the battery is charged, the needle will stay in the middle. If you were to jump start another tractor, or if the battery was low it would sur show the charge rate. Most do near nothing when running due to the excellence of voltage and charge control found with electronic regulation. If the alt is a 30 amp. a 30 amp meter is OK if higher output, the 60 amp meter is fine. Jim
