Re: wd9 Starting Problems
Posted by Dave Meisner on March 11, 2012 at 16:39:24 from (67.142.173.22):
In Reply to: wd9 Starting Problems posted by Dave Meisner on March 11, 2012 at 14:10:30:
It has spark, just seems like not enough suction to pull the gas up into the manifold. I have always been told that the valves need to be adjusted after the tractor has warmed up. Do I adjust the valves the same way on a cold engine? Thank you guys for your help. You all are great. There arent many people around anymore who know how to work on these beasts.
