Re: F-12 rear main felt seal question
Posted by Fritz Maurer on March 12, 2012 at 19:32:40 from (216.137.136.168):
In Reply to: F-12 rear main felt seal question posted by Seth Boyer on March 12, 2012 at 18:36:18:
I would trim the gasket back so the ends of the felt butt together. you're not going to need 'crush', as the felt will swell a little when you soak it. Do not install dry, that I'm sure of. I think that if the felt ends were separated,the oil would pass between the crankshaft and the edge of the gasket.
