Gas Tank Flow
Posted by Bud W on March 13, 2012 at 12:22:09 from (70.242.113.92):
I noticed that the gas flow into the glass bowl under the tank is really slow like drip,drip,drip when the tractor is not running. The tank is clean as is the filter inside the glass bowl. Does the fuel system rely on engine vacuum to maintain proper gas flow to the carb?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
