Re: Gas Tank Flow
Posted by Allan In NE on March 13, 2012 at 12:38:44 from (148.66.88.254):
In Reply to: Gas Tank Flow posted by Bud W on March 13, 2012 at 12:22:09:
No,
You had the sediment bowl off and then put it back on and it fills slow, right?
If the carb is full and the needle/seat is closed, there is no way it can fill until the needle opens. Air-locked if you will. :>)
I always leave the bail a tad loose until the bowl overflows a little; then cinch 'er down.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
