Farmall C inframe
Posted by picassomcp on March 13, 2012 at 18:50:24 from (50.107.32.51):
I hace recently purchased a Farmall C. The tractor does have a water pump, but has a 3" cylinder bore. Is there any way to positively identify it as a 113 engine? Or a 123 engine? Also I am looking to do an inframe overhaul on it due to the engine being stuck. I have the oil pan off and while looking at the engine from the bottom dicovered that I will be having a problem removing the crank because of the flywheel hanging on the back of it. Is it possible to remove the crank without splitting the tractor to remove the flywheel? Thanks for any help you may be able to offer.
