Another Glow Plug Problem
Posted by Alan Reynolds on March 14, 2012 at 06:00:53 from (67.142.175.27):
Thanks to everyone who helped with my question about the coil type glow plug indicator on BD154 engines. I've installed new glow plugs, but the system doesn't appear to be working properly. With switch activation the dash mounted gauge will swing full right, the coil indicator gets red, but the engine only appears to fire on one cylinder. Voltage readings are as follows: Battery 12.6v #4 cyl 4.5v, #3 cyl 1.5v #2cyl 1.5v #1 cyl 0v Another tractor sitting here has almost identical readings but it seems to start ok. My local dealer is clueless, but it seems to me that the voltage reading should be more consistant.
Any thoughts?
Alan
