Re: Another Glow Plug Problem
Posted by Janicholson on March 14, 2012 at 06:29:46 from (199.17.6.207):
In Reply to: Another Glow Plug Problem posted by Alan Reynolds on March 14, 2012 at 06:00:53:
If the readings you are taking are all to ground, the reason they are decreasing is that the plugs are in series. Measure each as a stand alone (both terminals on the same plug being probed) this gives voltage drop on each. (should be equal and a little less than 2v. (best guess as I am not looking at it. Jim
