Re: Farmall M trany/cluch problems
Posted by pete 23 on March 14, 2012 at 13:51:47 from (74.32.238.142):
In Reply to: Re: Farmall M trany/cluch problems posted by Janicholson on March 13, 2012 at 20:30:12:
I have read that original post over several times. If you push the clutch pedal in with engine running, how is he getting a noise anywhere by just pushing the left brake pedal. That is why I asked if he could get it into gear. I neglected to add, get in gear with engine running. The tractor should not be moving with clutch in. So, I assumed he meant it was in neutral, not moving forward and when he push's the left brake it then makes a noise. The left brake pedal is keyed and clamped to the shaft running across to the left side of the tractor and the clutch pedal also pivots on that same shaft. I have seen a counter shaft break inbetween the pressed on gears and force the shaft to the rear and that again pushs against that rear bearing forcing it up against that cross shaft the brake and clutch pedals are mounted on . After reading his diagnosis I have no idea what is going on. Could be a dozen different things. I would need a different version of his problem to make a reasonable diagnosis.
