Re: Farmall M trany/cluch problems
Posted by Janicholson on March 13, 2012 at 20:30:12 from (96.24.99.126):
In Reply to: Re: Farmall M trany/cluch problems posted by pete 23 on March 12, 2012 at 17:03:31:
Do you mean lower transmission front countershaft bearing and Liftall Drive shaft? If so the holes could be ovaled out in the casting/shafts worn such that it is dragging when twisted (normal when left brake is applied). The clutch pedal does not turn the shaft, it turns on the shaft. (part of this is clarification to the post. Jim
